Homemade 2 stroke flywheel puller
Fodeman
Rockville, Va
1000004726.jpg1000004727.jpgGuys, I've youtubed this many times, and after seeing others using screwdrivers and beating and banging on the crankshaft, trying to remove a flywheel, I said there's got to be a better way! I cut these 2 short pieces of scrap perforated angle to slide behind the flywheel. 1000004726.jpgI then took my gear puller and hooked it into the perforated holes of the angle and pulled the flywheel off. Works perfectly!
