dodgepolara500
I kind of like the sturdiness of the design!
http://www.instructables.com/id/Build-Your-Own-Faucet/
Because that looks really nice? Looks like something you would see on "there I fixed it" webiste.
I wonder what their verison of a Bidet would look like?
Actually, that faucet won't work very well as it's shown. Ball valves are great for quick on and off, but not so good for throttling the flow, which is usually what you want on a sink faucet. It would be okay for hose control. Next, you want symmetrical controls for hot and cold, not identical. It will fight a lifetime of past experience every time you use it. Plus the hot handle is awkwardly located. Finally, there's a reason that standard sink faucets feature an aerator on the spigot for a wider, more accurate flow of water for washing.
There was a TV programme on here recently called "Grow your own drugs" about herbal remedies before anyone says anything else! >>>
yes, disappointing wasn't it.![]()
Idea is sound, quality of work is half *** at best. Could have at least aligned the pipes so they are straight and positioned the valves correctly.
Somes of those ideas on that webpage are retarded..
http://www.instructables.com/id/Reduce-your-liquid-soap-usage-FOR-FREE/
When was the last time you didn't need 3 or 4 pumps of soap to get your hands clean? Maybe I'm not "normal" and have bigger hands than most or they are just dirty when I wash them, I dunno.
As far as "saving" water with the low flow b/s ... it comes out of the ground and goes back in the ground... it's not disappearing, so I don't see what would be getting saved.
