I'm looking to build an extractor that has a central suction unit that vents to the outdoors and has a flexible hose that I can position next to whatever I'm working on. I need something that can pull dust from bodywork out of the air as well as welding fumes and paint fumes (mainly just rattle can primer and guide coat in small areas).
I'm not really sure where to begin as far as what type of fan/vacuum unit I should start with or how many CFM's I'll need. I know I wouldn't need much as far as the fumes go, but the dust from bodyworking will require more and I have no idea as to that figure. I'm thinking a wall unit that's mounted to my currently unused vent fan louvers. With a section of pipe (probably just use PVC) run along the ceiling and then a flexible hose attachment at the end. I'm trying to do this as cheaply as possible. I don't need any kind of filtration, just a source of vacuum that will remove the dust and fumes from my work area. Anyone done this before? Or have an idea as to where to find parts for this kind of venture? Mainly I'd like to know where I can find a flexible hose that will keep the position I leave it in, and what type of suction unit I should use and where I can find it.
