Homemade roof snow guards?
jives
Central NY
Have any of you made snow guards for your metal roof? In particular, a snow fence that runs the length of the roof? It seems to me a simple piece of angle iron -- galvanized and painted or even a piece of matching roof trim of a thick gauge -- set on its edge and glued or screwed to the metal rib would work. I'm thinking something like this, but I would rather glue than screw.
http://www.contractortalk.com/f15/how-stop-snow-slipping-metal-roof-137043/index2/
Perhaps two or three rows to help carry the snow load.
Thoughts?
nehog
Jaffrey, NH
This is basically what I did, but I put one about eight inches from the edge. Works perfectly. I did screw it down, not sure how gluing would work.
J
jives
Central NY
Look up standing seam snow guards and go to images you get a lot more ideas
That is what I have done. I've looked at a gazillion images. Standing seam panels allow a clamp-like fitting, but a typical raised rib (e.g., PBR) roof panel does not. Plus, the standing seam snow fence guards are generally very fancy and expensive.
Any other ideas?
yeldogt
has anyone ever made snow guards for slate roofs?
They typically go up and under -- the long bar type require end fitting and you have to remove slates.
