Homemade Welder ...
zkling
If you were a true redneck, you would rather have the homemade job. ;)
redmondjp
Redmond, WA
Make fun of that homemade welder all you want, but have any of you ever taken apart a consumer-grade arc welder? I'd say that the homemade one is actually better constructed and probably has a higher duty cycle to boot.
Super Mech
Bronx,NY
Don't laugh. I actually made a stick welder out of old microwave oven transformers following the videos on youtube. I was curious after watching the videos a few years ago and i decided to make a project out of it. While it will stick 2 pieces of metal together, it has no heat controls. Just zap and go! Pretty cool project.
As for the DIY compressor- been there done that also. When I was about 15(now 50) I saw some plans in an old Popular Mechanics magazine. It used a York a/c compressor as a pump. I used a old propane tank from a forklift, found an electric 1hp motor in the trash. The only thing I had to buy was the pressure switch and some pipe fittings. I used that thing for years! Fun times!
Jure
Croatia
+1 yep..it has higher duty cycle for sure
Ign
Butte Peak ND
I know a guy here who claims to have done the microwave route for a homebrew welder. I've not seen it but as others have said, seems like a cool project but not practical for a great deal of actual use (regardless of duty cycle).
John in OH
SE Ohio & Eastern Virginia
Hey, these projects aren't as goofy as you may think!!
When I was about 14 (1964) I built a home-made welder as a 4-H project. A friend's dad was an electrical supervisor for a local mining company and provided loose wire and a scrap iron core and the instructions on how to build it. I spent HOURS insulating the wire and making the coils.
It actually worked OK! Output was about 90 amps AC and I could reduce this somewhat via a laminated iron block that could be moved inside of the main core. Got a blue ribbon for the project!!
About that same time I salvaged an old piston-type refrigeration compressor from a junk yard and built a compressor similar to that described by Super Mech above. Tank was an old air tank my grandfather had. That compressor would pump up a tire OK, but the capacity was low and I could never get the leaf-spring valves to seal tightly so max pressure was also limited.
Well, in hindsight maybe they were goofy projects, but for a 14 year old boy down-on-the-farm with his own welder and air compressor I thought I was really hot stuff!!!
IMHO, 4-H is, or used to be, one of the finest programs a young kid can join.
G_P
Central CT
In 3rd world countries, home made welders are very common. The on in that CL ad looks well built and probably works great.
Ign
Butte Peak ND
York compressors are still done regularly for OBA (onboard air) on trail rigs. Alternator welders are less common but more practical than a microwave for remote vehicle use. Then again 2 batts in series works pretty damn good in a pinch.
wiens80
There's probably more then $100 worth of copper on that welder. I wouldn't have the heart to, but someone could probably just buy it and recycle it, make a few bucks.
