ckucia
Was going through a toolbox and came across some hones I have. One's for engine bores and the other is for drum brake cylinder bores. They're the spring loaded three-prong ones that run off a power drill and have long thin rectangular stones.
Anyway, the adhesive has let go on some of them and the stones fell off the metal mounts.
I searched here and on the web and am unable to find out what the proper adhesive is. I could epoxy them on, but that would be permanent. I'm assuming they need to be held on firmly, but not permanently so the stones can be swapped out when they wear or to use a different grit.
Is there such an adhesive, or should I just epoxy them on and get new hones when they wear out or I need a different grit? These aren't anything special - they were cheap auto part tools I got probably decades ago, although they have done the job when I need them.
Not something I need right away, but I thought I'd fix them so they're ready when I actually need them...
