rjacobs
Weve been in our house for 4 years now and every winter our electric bill is higher than in the summer... We live in Texas, our summers are brutal our winters, overall, are mild. I always questioned it.
In the winter we run the house during the day at 66 and at night let it cool down to 60. I read something recently that if you let your temp difference get to great that your heat strip backup will kick in and can cause really high electricity usage... The air coming out of our vents when the heat comes on is hot... I dont remember that to be the case in my old house that had "emergency heat" on a switch which activated the heat strips if it got to cold outside. I also dont remember that in the house I grew up in that had heat pump heat with "emergency heat" strips on a switch.
Im FINALLY looking at this so I went into the advanced menu in the Honeywell T6 Pro thermostats and see that code 340 "backup heat droop" is set to zero. This to me means that my heat is 100% coming from my heat strips and I am never letting my heat pump do anything basically. I checked code 205 "heating equipment type" and its set to 7 for "air to air heat pump".
So I am thinking I need to set my "backup heat droop" number to something other than 0 in order to let my heat pump actually work without having my heat strips kick in... Is there something scientific to picking this number?
I think I would be ok with bumping up my night temp if it means keeping my heat strips off and relying on the heat pump(which is what we SHOULD be doing)...
