Kinger
A while ago I picked up a Hot Dawg 60 unit heater for the garage.
I am finally getting around to getting this thing fired up. Part of the reason I got such good deal on the unit was that it was set up for LP.
I purchased the LP to NG conversion kit. I have switched out the orifices on the burner. I now need to chagne the spring inside the valve per the instructions.
My trouble is that the screws holding the valve together look like tamperproof torx, but none of my tamperproof torx bits fit. A closer look and the heads appear to be a 5 point tamperproof screw.
Can somone point me in the right direction to get the appropriate tool to finish up this job? It is getting cold here and I am really looking forward to having some heat in my garage!
Thanks
Thanks
