johnwilliams
I have a quick question:
I am setting up a HOT TUB it is 240v and I have a Cuttler-Hammer GFCI 50a Breaker installed in breaker box.
Now I see three(3) slots for wires one slot just below it has a white (PigTail) wire coming out of it and is connected to the GROUND bar inside the main panel box.
Now I do know that there are two legs coming out with 120v and one leg (Neutral)
I know the two hot legs will go to the line 1-2 leg on hot tub for the 120v current = 240v for tub operation. I also have two things that are 120v that need to run.
MY QUESTION IS: Does Neutral coming out of the back of the GFCI Breaker have current that will run the 120v items on the HOT TUB??
I also have a ground rod beside my HOT TUB does the ground wire (solid copper) hook to the ground lugs on the electric motor and the control panel inside the HOT TUB Housing.
