smalltown
Tying to use a used to me JET 5x6 band saw.
After replacing some incorrect sized nuts and bolts to get it back to where it should be I bought a new Starret (could not find a Lennox locally) blade.
Every thing is running as it should except the blade keeps popping of the wheels when I start to cut. All I am trying to cut is 1" EMT conduit. I adjusted the tracking so the blade is running just near the back edge of the wheels.
I am worried that if I tighten the tension too much I will break the new blade. After additional tightening I did get it to cut half way through the conduit, before the blade popped off again. Do I really need to crank on the tension adjuster ?
