joseywales
This is so simple and I can't understand why it's not working.
I had an existing outlet. It looks to feed another outlet as well. My plan, was to add an outlet 2 feet above it, on the other side of the wall. Then, run from that outlet to a set of switches: 3-gang box - 2 dimmers and 1 paddle. Doing all this, to add 3 new lights to the room
1 - i ran the power from the existing outlet to the new outlet. It worked. I didn't check polarity at that time.
2 - I ran power from the new outlet to the 3 gang box. All lights and switches work.
3 - I wanted to check the polarity of the new outlet as a CYA and sure enough, the Hot and Neutral test reversed. The existing outlet tests fine.
Since the existing outlet tests fine, the problem would have to be between the existing outlet and the new outlet, correct?
The wires on the new outlet are: Black (hot) to the small slot, and White (neutral) to the long slot, same as on the existing outlet. I even tried reversing the wires on the new outlet, with no change.
It's a straight run, from one outlet to the other. Any ideas? Is it possible that one of the lights or switches is causing the issue?
