Hot/Cold Parts Washer Machine Suggestion?
2JZGTESC300
California
I'm installing a Rebuilt 1985 Ford F150 V8 Motor and also rebuilding the 4X4 Transmission in the truck as well. The truck has lots of grease on the Motor and Transmission. Enough to cover your entire hand with gloves every time you go and try to unplug sensors or vac lines.
I have a small portable parts washer, but that's not going to do in washing huge parts.
Need advices on up to date Hot/Cold Parts Washer Machine that will recycle the washer solution with a filter that re-use the cleaning solution over and over. Would prefer a Open standing Hot/Cold Parts Washer Machine where one can stand facing it and do the cleaning of parts.
Any comments on brands that you actually have used, or own.
What cleaning solution to use?
Fedwrench
Valley of the sun
Cuda and Mechanics buddy hot water parts washers but, they are not cheap at all. They work outstanding though!!!
I have seen upright but, not open. Chemicals+ hot water+ open+high pressure spray=OSHA issues.
Find an older Maytag JetClean dishwasher. The 10-20 year old units are POWERFUL and actually cascade and the like make decent degreaseers, too. Remember to have iit on the HOT cycle and heated drying, and not a lot (If any) will be left when its done with the long harsh cycle...
You can collect the water in less than two 5 gallon buckets, and let the water evaporate, then dispose of the scrapings.
