bmallak
I picked up a Hot dawg HD75 and got it hung. The manual says horizontal venting minimum 3' and maximum 30'. I should be around 6' linear feet with 1 45 deg elbow that adds 5' according to the manual.
1.The way I read it it calls for a drip leg/clean out cap. Is this necessary?? All I seen at menards was a tee with a cap but is this what I would use?? how do you seal the cap ?? What would the Tee be used for? There is a smaller hot dawg installed in my attached garage that has no T but is vertically vented and has been fine for 12 years.
2.Also what do I use to attach the b vent to the heater. I bought a 3" universal adapter but its to big to match the 3" on the heater.
3. The Heater is going in a pole barn with walls that are 7 1/2" so the standard thimble doesnt reach. Can I use aluminum tape on the inside to conect the two pieces or does someone make a thicker wall thimble?
Sorry for the long post but am looking for any help. Thanks.
