Hot tub issue
eddieK
Nampa Idaho
Not sure where to post this question - Mods feel free to relocate this
I have a 300 gallon hot tub. It is a Viking brand spa, it's about two years old.
Lately I have noticed I have to keep bringing the water level back up every day (drops about 3 o 4 inches). One morning while sitting in it I heard a drain inside leaking, so I opened up and the spa and so that the next time I sat in it I could see if it was what I heard draining. Sure enough, before getting in the spa it was not leaking but after entering the spa and the water level rose, it started draining.
I didn't want this to keep draining under the spa so I connected to the hose and routed it outside the spa. This "drain" did not drain when the pump was running, only when the pump stopped.
A little more investigation and I discovered this is in fact not a drain but an air line for the air control valve.
This is where I am now, wondering if anyone here has experienced this and has any info before I delve deeper into this. I live in San Diego, freezing is certainly not one of the causes.
Thanx in advance
3504speed
PNW
My Viking leaked at the topside control panel. Of course it only leaked when I overfilled it and two were in it. The topside control got to the point where I couldn't read it anymore so I ordered a new one thinking it would be my chance to make sure the seal was good this time . The new control panel with the two sided tape fixed my leak. Sounds like you have a different problem though
E
eddieK
Nampa Idaho
^^^,I'm with this !
Jay D.
No. That hose is air ONLY(when working properly)...it provides air so that when you open the air valve it doubles the pressure. What I do know is if one of the valves fails, the air line then leaks because water has been introduced to it.
I'm hoping someone else has run into this problem.
