Hot water heater for the shop - exploring options
poppinjohnnies
Kansas
I have a small bathroom in my shop with a shower, along with a sink behind the bar. I’m getting ready to finish the bathroom and shower, and the current 1 gallon water heater under the sink barely makes enough hot water to wash a pair of beer mugs.
So I’m debating whether to run wire and 2 breakers and install a 18kw tankless heater, or swap the little tank heater for a 120v 10 or 20 gallon tank heater in place of the current one. My water is fairly soft. Any opinions on this?
u2slow
BC
18kw is a substantial load. Do you have the headroom on your electrical service?
I would do a tank heater. On a timer or switch.
PCustoms
VT
Why do you need to heat hot water?
Go with a larger tank heater
Crazyjake8493
Upstate NY
We use 120-volt point-of-use water heaters at work in bathroom or small break room additions when necessary, usually around 7-10 gallons. Plenty for washing your hands or washing some dishes. For a shower, you may want to go with a larger tank.
BurtEggley
If you are the only one who will be using it, a small one that has a long recovery time is all that is really needed.
mike93lx
Richmond, VA
I'd do a tank unit.
How often is the shower used and does it need to be able to run for long times? I'd probably lean to 20gal, but 10 gal of 140 degree water can give a plenty good shower if you use a flow restricted head and don't take your time
finn
The UP, God's country
The water in my late mother’s Florida condo was what I considered hot, but not hot enough to take a “hot” shower.
Hence, the condo needed a hot water heater.
Same with our house in Tucson, at least in the summer .
That Guy Scott
SoCal
I have a 13kw heater in my shop and it works great. I have 2 sinks and a shower off of it. The biggest thing is to make sure you have the correct gpm faucets in order to slow the water down enough to heat it. Or buy an oversized unit.
dcg9381
Austin, TX
I did a 3-4 GPM "tankless" propane heater. It was <$400.
In the "converted" cargo trailer, I get by with 3 gallons of hot water in a tanked heater. Good enough for a quick shower, which is outdoor only... Certainly no reason an 18kW tankless won't get it all done, but that's a lot of power. 10 gallons of hot water in an RV is "luxury".
Part of it is the "incoming" temperature of the water. 3 gallons of 120F hot water lasts a lot longer when the cold water temp is 70 degrees... If it's 40-60F, showers get a lot shorter.
Norcal
I lived with a 10 gallon electric water heater many decades ago learned to shower quickly with a low flow shower head would have been better but was not a option, a 10 gallon WH on a timer would work well.
SouthernIllinois
I put a 30 Gallon electric in my tool room.
I have a deep sink in the shop and a double deep sink on the patio end of the building.
It gives me enough hot water to wash my hands, wash dishes on the patio and wash the car, truck and the Gator.
nadogail
Coronado, CA
My shop has a small 125 Volt under sink water heater maybe 3 gallons. No shower but plenty enough for hand and paint brush washing.
It would be big enough for a shower if I showered like on a Submarine.
Worsedog
Central FL
I put this one in place of 30 gal tank style.
According to the size charts it is oversized for 3/4 bath in the garage. Besides the expected GJ overkill is our friend mantra, there was also practical reason for going this route. The proper size one required a 50A circuit. The one I bought required two 30A circuits. It was much easier to run a second 30A and I already had the appropriate wire on the shelf.
It's been in place six years without issue. Granted it doesn't run everyday but it works. The reviews were generally good, so I took a chance.WH.jpg
Hellpig
Southern MD
From how far out of the box do i.you entertain ideas?
Military M67 Liquid Fuel Fired Immersion Heater.
Think I still have a few milsurp NIB still
laying around
