jabberwoki
I have a small hot water heater in the shop that's not working. About 3 weeks ago i swapped out the element thinking that was the prob but it did not change a thing turns out some of the wire nuts were loose it was registering power but not enough amps.
So after snugging the nuts up every thing was rosy until 3 nights ago no hot water. So the first thing i check was power at the element that's good so even though the wire nuts were tight i soldered all the connections up no difference so i checked the volts at the element 119 so i put a new thermostat in no difference?
I borrowed a amp clamp from a mate but it does not work i`ll take it back and see if he can get it going.
In the meantime any suggestions?
Thanks.
Thanks.
