I'm in the process of cleaning up the previous owners DIY job on the hot water heater vent. Wrong materials, duck taped joints, backpitched, all sorts of fun stuff.
My water heater sits next to the furnace and the water heater exhaust joins the furnace exhaust and both exit out the roof in the same vent. Part of the problem is the furnace exhaust vent is not properly supported and has dropped down a few inches. My plan is the raise the furnace exhaust to the proper height and replace the water heater vent with all new pipe.
First of all, what is the proper way to support the vertical exhaust? Do they make a special clamp type hanger specifically for this application?
Second, what is the correct pipe material to use for the hot water heater vent? Basic single wall or do I need double wall?
Thanks for any advice. It should be a fairly simple job, I just want to make sure I use the correct materials.
