the hot is most likely the least corroded brass connector, the one in the right of the picture. to be sure , take the connectors off, the cold inlet will have a plastic tube in the center, called a dip tube. that sends the unheated water to the bottom of the tank
actually when I blow up the picture, the tag on right says do not apply heat to this connection. that's probably the dip tube ( cold side)
