Not quite sure how to describe this, but here goes:
We have Two (gas) forced air heaters in our single-story home.
The main (larger) one heats all but the kids' bedrooms, which are on the far end of the house.
The heater for their rooms is in the attic, w. the thermostat in one of their rooms.
The programmable thermostat and heater were installed new about five years ago.
None of us have ever programmed the thermostat, just set the temp. and leave it alone.
Over the last few months the thermostat has been occasionally/mysteriously setting itself to a higher temp. at night, typically in the mid-seventies range.
This morning I smelled a hot wax smell at their end of the house and when I went to investigate I saw the thermostat set to 84 degrees, the system switch in heat position, the fan switch to "on", but no fan running.
The wax smell was definitely stronger in their rooms, strongest in the room directly under the heater. Went up in the attic and gave the heater a visual once-over/sniff-over. The smell was a little stronger up there, but I didn't see anything unusual, so I unplugged the heater for the time being.The boy in the back bedroom said he woke up in the middle of the night and turned down the thermostat because it was too hot, and said it smelled strongly of hot wax.
So, I'm guessing that the thermostat went wacky; the fan motor burned out; the heater shut down.
But the hot wax smell?
I'm a little freaked out by this! Had a family chat with the boys to re-confirm that they need to come get me anytime 24/7 if there's anything unusual like that going on.
