Hot work outside?
bad_idea
Pasquotank, NC
I guess it would have been better to ask this at the beginning of summer, but... How do you all do grinding or welding outside? The little bit I did out in the driveway left rust stains on the driveway. I tried to use a torch to cut material in the back yard and kept setting the lawn on fire.
thightower
oklahoma
A scrap piece of plywood, usually 1/2 or thicker, or sheet metal works good for a shield for sparks. I know the plywood don't make sense, but does work good as long as you don't put the torch directly on it. It may smolder a little, but its better than a fire in the yard.
slip knot
Texas gulf coast
I use a piece of plywood myself. Soak with a hose and get to work. the worst it will do is smolder some.
We've been in a drought here for a few years and I get real paranoid about grass fires and this method has been the best for me.
bad_idea
Pasquotank, NC
Water and hot work hadn't occurred to me. Not a terrible idea. I am familiar with using plywood to contain hot work. We usually use fire retardant plywood to build containments at work. (I work in ship repair)
camarotoolman
cocoa Fl.
Please be careful not to set your clothing on fire, had an old friend die that way, not a good way to go. About a year later my uncle was hurt bad welding, he set his pants on fire.
