Hour meter?
scrapart
Ok so I have a brand new Quincy air-compressor and I don't want to play the guessing game on maintenance and I'm no good at writing stuff down. I'm wondering if there is a way to install an hour meter on my air-compressor?
Burtonrider10022
Chicago, IL
[URL=http://www.amazon.com/Vibration-Activated-Hour-Meter-Equipment/dp/B009PEQVMS/ref=sr_1_3?ie=UTF8&qid=1352721886&sr=8-3&keywords=vibration+hours+meter]Vibration Activated Hours Meter - $18.99[/URL] said:
Vibration Activated Hour Meter No Power Required Use for Trailers Motors Equipment Machinery
Functions:Hour Meter
Weight:60g
Rec/Displays to:9,999.9 Hrs
Operating Temperature:Standard -30°C to +85°C
Resolution:0.1 Hrs
Track the Service Life of all Non-Engine Applications - automatic vibration activated recording.
No Power Required - sealed waterproof lifetime battery inside
Preventative Maintenance - bearings, chasis lubrication etc...
Easy Installation - peel & stick, no wiring necessary. Just plug and play!
Records & Displays to 9,999.9 hours
Hour glass symbol appears & flashes on/off to indicate counting time.
Automatic Roll over
100% epoxy encapsulated casing resists water
So... this should work...
malibu101
Walnutport PA
Weight:60g
Resolution:0.1 Hrs
Automatic Roll over
See my underlined in the above.
What is the lifetime of the battery that is sealed inside? :headscrat
