ToddW
It appears my house mounted panel can't handle double lugging and doesn't have feed through lugs to feed my shop and the biggest CB is <100a.
I don't want to replace the house panel and have to update everything to code that would be insanely expensive since this house was built in the 80s and not much has changed.
I'm HOPING there's a way around this with a part I can't find by either not being common or knowing the proper name
- House doesn't utilize much power, would be sufficient with 100A but ideally would like to keep the 150a available, 200a ideally.
- Need to handle 3/0 wire to my shop for 200A via feed through lug or 200a breaker
I'm hoping for a scenario like this:
- Meter Panel + 200A Main Breaker
- Feed Through Lugs for garage (3/0 capacity)
- CB with 150-200A capacity to feed existing house main meter/panel combo wired from top to existing panel.
I think it's called a Meter + Main Breaker Combo and the main breakers can be used to feed the house panel and/or shop panel or use feed through lugs.
Suggestions?
Not 100% this would prevent having to update the house stuff since it would be a new meter but existing panel would be used.
Suggestions?
