Deadhead
So its 10:45 pm and the wife realized the heat is not working in the house.
Pull the panel - depress the door switch and the control board is flashing a Thermal Protection Device Open code.
I start checking everything and get down to the high limit switch.
I did the paperclip jump and it fired up,
it run like it should with a good flame,
ran for a heat cycle shut down like it normally does.
Minutes later it cycled again fired up and did its normal thing and shut back off.
Basically its working like it should.
I fully understand that I could have a thermostat malfunction and it not shut off and do bad bad bad things to my unit or worse, my house.
My question is how long can I run it with the paperclip jumping it.
I can get a switch in the morning from my heat and air man but its going to be down in the single digits tonight and I need to keep the house somewhat warm.
