House humidifier question
kippieland
Western Washington
We had a Honeywell True steem humidifier installed last year. Its been very dry in my area (everyones hands are cracking) so I turned it up to 40%...manual recommended 35%. We are now hearing a lot of noise from the unit that is echoing through the duct system. The noise sounds like the humidifier is working (bubbling noise or thuding noise) but I don't recall ever hearing that noise last year..even when it was up higher. Is this a normal sound for this unit? Its had its yearly servicing and I just cleaned it two-weeks ago...seems to be building up calcuim fast compared to what the manual states. All the lights are green on the system as well. I know its a hard question to answer online, but I thought you guys might be able to help!
Greatbear
Columbia/Fulton, MD
Your humidifier might be boiling due to reduced air flow. Make sure your filters are clean, all the registers open and the furnace fan and heat exchanger is clean. If you have mineral deposits in the unit, make sure the heating element is completely clean. Also be sure that the temperature sensor is not dirty or outside the water level.
I had a steam unit for a while which worked well, it needed thorough scraping and cleaning each season. The electronics went out on it, and I have not gotten around to replacing the unit (they are outrageously expensive). The newest version of that unit has an automatic drain valve which goes a long way to lower the amount of mineral buildup inside.
bd8134
Franklin, MA
I installed the same Honeywell unit on my house A/C. The unit is mounted in my garage as the fan coil is in my attic. It is connected via a rubber hose maybe 8' long. I hear no banging or noises from my inside the house. The unit does click to open the valve to allow water in, make a noise from the boiling water and also when it automatically cleans to purge the water. I suspect kippieland, your unit is directly mounted on your ductwork, maybe in your basement. Have a check on the mounting screws to see if they have loosened or maybe install rubber mounts. I suspect the noises you are hearing are normal from the unit, but you should be able to quieten it down or find why it is making more noise this year, maybe the 40% setting increase is the reason. It does make a noise like a boiling kettle when it is on.
I have my unit attached to my a/c controller which has a humistat setting. It has an automatic mode for humidifying which uses an outside temp sensor to adjust the humidity level. At lower temps it lowers the level at which the humidifer turns on at. This is so you do not get condensation on your windows and mold. So depending on your outside temperature even 40% may be too low. At times my unit is providing 45%. When I recently cleaned my unit I was surprised at the amount of buildup inside the unit. My house water is filtered plus I use the units water filter. My unit is in use a lot but it does make my house more confortable and stops the horrible creaking noises we were always getting from the house in the winter.
