Our post frame building has been built, and in 50/50 hindsight, I realized I wish I had asked the contractors to install house wrap. We live in Oregon in a wind corridor (our wind even has its own name), and it seems like wrap would help limit air infiltration. We plan on insulating and putting up walls once we fix a few other problems. Eventually the whole building will be temp controlled.
I really don't feel inclined to remove the siding, wrap, and replace it. But I'm wondering if it would be worth putting tyvek up from the inside, stapled to the girts / posts and seam taped. Then follow with insulation. It seems better than nothing and a lot less hassle than taking the siding down.
We do have one shear wall that has plywood behind the metal siding, nothing in between. If we wanted to wrap that wall, we'd have to remove the siding to put the wrap between the metal/plywood. Anyone feel that it's important enough to add that barrier that we should do it? Or is plywood in direct contact w/ the metal siding not that big of a deal.
Thanks!
Thanks!
