House wrap or 6 mil poly?
383 240z
Findley Twp. Allegheny Co.
I'm ready to start the wainscoting on my build. I have tons of 6 mil poly available to me. Would this be OK to use instead of house wrap? I'm not going to spray foam the building (unless I hit the lottery soon) but i still would like something between the steel and the posts and stringers.
The plan for the interior is foam panels for insulation in the walls with plywood for wall coverings. Blown in insulation, metal roofing for the ceiling, with a metal roof.
Good idea or bad idea?
marak
Anchorage, Alaska
Perm rating of 6 mil poly is 0.06.
Perm rating of house wrap is at least 5.0, per International Code Council.
Perm rating is a measure of the amount of water vapor transmitted through an area of material. Interior and exterior paints have different perm ratings because they have a different function regarding vapor movement.
u2slow
BC
Tar-paper. It met Code for my shop build in 2013. (Heating climate)
I don't like house wrap because a shop building is rarely kept warm enough to turn liquid into vapour for the 'breathing' to work.
jack stand
Lakes Region Maine
I can't see much in the picture, but that left (hillside) worries me (a lot) . Do you have plans to get the runoff around the building and continuing downhill?
firebirdparts
Kingsport, TN
I think poly on the inside and nothing on the outside is the only reasonable option for using poly. Water will not be "trapped" in that scenario. Whether or not you like that option of nothing outside is another question.
Practically everybody in the south has bubble wrap or vinyl faced insulation on the outside, so it's not apparently critical to avoid that either. Nobody building garages worries about it. FWIW. They could all be idiots, I don't know.
u2slow
BC
Metal siding will condensate on the backside, so you want something behind it to prevent lumber and sheathing from getting wet.
