bluedog225
What do you guys think I should do with this?
This is the 4 inch waste line from my workshop to the septic tank. The building is set on nine 20’ deep concrete piers. The septic tank is set about 6 feet down on undisturbed soil and a bed of gravel. The soil of that depth is sand with clay.
One of two things has happened. Either the septic tank is settled in, or this is differential movement between the deep foundation of the workshop and the relatively shallow foundation of the septic tank.
In anticipation of some differential movement, I had them place a flexible coupling between the pvc plumbing coming out of the septic tank and the foundation. Obviously it wasn’t sufficient for this amount of movement.
I’m going try and find a larger flexible coupling. Or I’m going to extend the PVC and reuse this shorter coupling. And see what happens.
It’s been dry. And over the seasons, I will come to find out more information about whether this is a permanent settling or if it’s going to be something I have to deal with seasonally.
I’m open to other ideas or suggestions. Thanks.
