How are the pros cutting EMT? Scoring tool?
rust in the eye
Chicagoland
For my own projects a recip. or hack saw has been my go to. Of course all the cuts required deburring which is a PITA.
A Klein scoring tool made it on my radar so I bought it but will be damned if I can manipulate this thing. My understand is to SCORE the pipe and break it off cleanly (right) but my results were always bending the pipe. Scoring deeper was tedious and probably abusing the tool and with less then satisfactory results so I gave up.
So, Sparky, what's the trick for using one of these??
aka Larry
Eastern, NC
When I built my shop I used a side grinder for the cuts. I used a flap disc to hit the out side and found a uni-bit was perfect for the inside de-burring.
Chuckster in NJ
Hunterdon County NJ
Milwaukee M12 portable band saw and clean It up with a Klein EMT reamer.…….. In the old days I always used a hack saw and the Klein reamer or square shaft screwdriver.
I used a 120 volt Porter Cable Porta Band on the larger sized EMT.
BTW! I never used a tubing cutter even though some guys used them.
IMG_3235.jpeg<<<<< Klein EMT reamer
sparky 1971
Central Iowa
Bandsaw almost exclusively for the last 12ish years, Hackzall for a whi!e before that, and a hacksaw for a long way time before that. TBH, A hacksaw with a 32 tpi blade is the fastest way to cut EMT. Then use a reamer or needle nose on the inside and Channellock's on the outside to deburr. The only time I use a pipe cutter is the extremely rare occasion that I am going to cut an existing pipe with wires in it.
micromind
Fernley, Nevada, about 30 miles east of Reno.
Pretty much same here.
dscheidt
Milwaukee sell a reamer that snaps onto one of the pulleys on the cordless portabands. it's a fantastic addition to an already fantastic tool.
willf650
I’ve used a hack saw, sawzall and currently a small porta band. Reaming was generally just with a set of channel locks. I’ve put in 1000s of feet of conduit in this fashion and never had an issue.
As far as the tubing cutter the Klein one is a recent thing and you won’t ever find anyone using it as a regular thing. I don’t own one but have always used a tubing cutter but the only time I’ve ever done this is when I had to cut a conduit that had wires in it I couldn’t easily remove and had to reuse them.
this is what i use as well
alfredeneuman
Fullerton, CA
I've owned 2 of the Klein 1/2" EMT cutters and I regret ever buying them.
Like an idiot, I thought the first one was faulty, and bought another.
Absolutely it's the worst tool Klein has ever produced.
I've owned multiple Dykes, Screwdrivers, Wire strippers,and Lineman's Pliers. and all were completely satisfactory.
which klein cutters are we referring to? i have yet to come across a klein tool i didnt like
sparky 1971
Central Iowa
Probably those POS tubing cutters like a plumber uses for copper. I had Greenlees version that was the same thing and threw it in the dumpster after about three failed attempts. I now use a Lenox when the need arises.
jbltwin1
Godfrey, IL
I LIKE to use cutoff wheels if I have one handy, and I usually do! fast, easy, and don't leave that ridge like tubing cutters. If the cutoff wheel isn't available, just a hack saw. Usually use a rat tailed file when I can't see the reamer.
yeah i hate those. they create a rolled lip that can catch wire as you pull it thru the conduit
sparky 1971
Central Iowa
The lip isn't too bad if you use about 3000 turns to make the cut, barely tightening the wheel as you go. I don't use one unless the rare occasion comes up that I cut a pipe with wire in it because I'm too lazy to pull it back or have no effing clue where the next junction box back is so that I can pull that wire back.
micromind
Also, it's a royal bear to ream the inside of the pipe without skinning the wires, especially if they're hot and you'd rather not blow stuff up.
Norcal
Bought one myself too, waste of money now gathering dust for a lot of reasons.
alfredeneuman
Fullerton, CA
The only halfway successful way I've discovered to break after scoring the conduit without bending it is to hold the conduit tightly in a vise and use a piece of pipe or a bender handle over the EMT for leverage.:mad:
R
rust in the eye
Chicagoland
This is what I saw demonstrated in YT video. Getting the right cut depth and monkeying with a another pipe over the pipe was all way too clumsy for me.
Glad to hear it's not just me that has trouble with these. Somebody must be using them with success or Klein wouldn't be offering them, beats me who.
Off to Ebay she goes, curious to see if and what it will go for.
sparky 1971
Central Iowa
All of these other ways just sound like lots of time lost and extra complication. Sounds like trying to scratch your left **** cheek with your right hand raised over your shoulder.
This is Garage Journal, where the simplest of tasks are almost always more difficult than moving a mountain with a teaspoon.
willf650
I think the obvious answer is ”Pros” are cutting conduit with some form of saw, preferably a portaband.
As far as the Klein tubing cutter no one using anything in that regard unless there is a specific need to cut a conduit with wires in it. When cutting conduit with a tubing cutter I’ve never had issues bending the conduit but using one is very infrequent.
Norcal
By the time someone fiddle farts with that tubing cutter a Porta band or a Sawzall would have cut it.
Crazyjake8493
Upstate NY
Portaband and deburring tool on an impact driver. Hacksaw on occasion if needed. I've used a tubing cutter once or twice in really tight spots but not the ideal method.
BreeStephany
Oregon
When it comes to EMT, a band saw for anything larger than 1", metal cutting circular saw for everything smaller. For 1/2" - 1" I use a Klein conduit reamer, for everything else I use a pipe deburring tool (little pen looking tool with the crescent blade on the end).
When it comes to rigid, I have a Rigid 300 power head, cutter, reamers and adjustable threading die.
BreeStephany
Oregon
The Klein EMT scoring tool is decent, but definitely a lot slower, especially when you are running thousands of feet of conduit per day.
I was on a LONG electrical project in an active food processing facility where we had to either score cut conduit or walk it out to the loading dock to cut ANYTHING with a saw.
The Klein conduit scoring tool and Ridgid StrutSlayr were invaluable on that project.
