Hooked up a shop built heater for a pull tester today. I’m using an inkbird temp controller with a solid state relay. One of the 8 heater cartridges burnt off a lead as soon as it was plugged in. (Maybe I should have the wire end of the heater slightly proud of the Al block they are in?). Any way it fried as soon as it was pluged in. The ssr is only switching the hot (black wire) on a 110v circuit. Found out the outlet that it was plugged into is wired backwards. Not a big deal for most things. I’m going to correct this, but should I go crazy and check every outlet in the shop?
