how best form for final slab in barn/shed
Backwaterdogs
Illinois
Not sure if this is the right place for this question or not, but pouring a final ~10x40 slab in my shed (long over due)...this is going in a metal quanset style metal building.
ykY5DnY
MRJJB3D
ZVQD6k7
KqY5fHs
My concern is, there is already a footer/foundation there, but too high that I can't use it as a strike off. so, not sure how to word, this other than I need to maintain a slope from existing slab to the existing foundation...so need the concrete line to land about 3/4 inches below top of that existing foundation.
Was wondering if anyone has encountered where it's not clear/easy to strike off the concrete. Do you just eyeball it?
joes169
WI
We deal with this on an almost daily basis, it's referred to as "wet screeding". It's definitely more complicated than screeding directly off of the top of a form, but once you've done it over a few thousand yards, it's nothing to worry about........
You may want to mount 1/2" felt/ripped insulation to the foundation to run a mag off of before the pour, it will simplify the entire pour. Plus, it's ideal to have the separation between the two concrete elements.
ConCretin
Central Maine
As joes169 indicates, an experienced crew won't have a problem establishing grade without forms using a laser and wet screeding. I like his suggestion of installing expansion material to the existing footing. It will provide a reference for grade similar to a form board for striking off the concrete and isolate the slab from the footing. I usually use a closed cell foam material with a removable top strip that can be pulled out to leave a space for sealant. We call it zip strip but that term has multiple meanings.
