454ragtop
At a shop where we work on our hot rods there are 2 compressors, a large horizontal with a Kellogg 331TV pump, 5 hp, and a rather sad old vertical that I never paid much attention to. The 5 HP motor on the horizontal appears to have burnt out. Been using the vertical, but it really doesn't put out much air. For some reason I got the idea to look at the vertical setup to see if by chance it might be a 5 HP also, and was pleasantly surprised to see it is. But, the weird thing is it's driving this little dinky Speedaire single stage pump like would come on a portable compressor, model # 2Z630C. I want to swap the motor to the horizontal and put another motor on the vertical to keep it as backup. It certainly doesn't need 5HP. Been searching online to try to find the specs and recommended motor, with no luck. I did find an old auction for the same compressor, and it is a little portable, pic from the auction below. Auction had no info on the motor, of course. Do you think I could get away with a 1 or 1-1/2 HP motor? Anybody have a source for specs.
TIA, Jim
TIA, Jim
