bobinyelm
Not sure where is the right place to ask, so I posted it in 2 places.
It's not an "electrical" question, so I thought maybe here was appropriate?
I am about to start wiring my new 32X60ft shop, and there are places that the wiring "needs" to pass through the structural poles that are 6"X8" or 8"X8" depending where they are located.
Is there a place one can find tables or such that say how large holes drilled through the vertical support poles can be for the purpose of running wires? At corners, I would drill intersecting holes at 90 deg to pull wires through.
The inside of part of the shop is studded flush to the inside surfaces of the square poles, so installing conduit is otherwise not required since the wiring will be behind sheet rock as in a conventional building.
ALSO, there is a 1 1/2" space behind the posts (the sheet metal sheathing outside is spaced by 2X6s off the posts. Is it OK to run the NM wire behind the posts (between the posts and the vapor barrier/insulation that is against the inside of the steel siding)?
