The heaviest load id put on it would be lifting the front end on my Dodge 2500 diesel one side at a time. I have a 2.5 ton right now but want to get a better one because it isn't smooth and tends to drop too quickly. Its an older HF 2.5 ton.
I don't see that you would need a higher capacity than that, maybe just heavier duty. I have a 2-ton and 4-ton, both very old, and either one lifts one side of one end just fine. (Of course, don't get under there with any jack as the only support. I dropped a 1966 Lincoln on myself that way.)
I ran my Ram to the Cat scale last weekend. 4500lbs on the front (4wd).
My current jack is a 2.5T but I don't feel comfortable using it. While it's still within weight, it's narrow and has a small seat. It'll do but I want a nice wide 3T instead. Least for some stability and some peace of mind. I used this 2.5T on my small suv in Japan. I had an instance when I thought it moved on me, tipped rather, when I had it pretty extended for suspension work. Made me nervous so I'm not thrilled to use it on the truck. Especially that the jack points on the axles are up higher than the last truck.
this jack i have now definately strains on my truck and takes several more pumps than when i use it on the car. i think that the hf 3 or 4 ton would be a good choice and they have gotten really good reviews. now, if i can just find a coupon. there are a ton of them for sale on ebay but i just can't bring myself to pay someone for something that they really don't have any business selling.
