Justind97
A couple of weeks ago I went into the garage and thought, WOW, it's really cold. I looked at the thermostat, set to 60 was reading 40 (40 is the lowest it will read, so it could have been colder).
Put the switch to off, then heat again and away I went.
Come this Saturday afternoon, same thing again. This time the furnace would cycle on for 8-10 seconds and then shutdown, did that 3 times and went into lock out.
Stumped and frustrated, went to google. Normal issue, you have to clean the flame sensor...
Sure enough, my flame sensor is mounted with the screws in the opposite direction and I had to take 1/2 the ****** thing apart to access it.
Cleaned the sensor with #0000 steel wool and it runs perfect.
Question is, is this sensor reading heat or what? The before/after cleaning looks near identical. I can't actually tell I cleaned anything off.
