How can I move this tv ?
The Cobbler
didn't read all posts so forgive if its duplicate. 14 or 16' 2x with ply fastened to the backside. pulleys on the 2 x with ropes to the floor. lash tv to the ropes, tip it over onto the slide and lower to floor with ropes . You still need 3 to 4 people I would say
JRC3
Southwestern OH
Some of you all have been watching too many Wiley E. Coyote cartoons. Remember, it never worked for him.
GTFiero
Sawsall. Opps. That's what I did with the projection tv in basement.
HotrodHR
North Alabama
Shove the bed under it and push... hope it lands on the mattress.
The question I have is... how in the heck do you watch a TV 12 feet from the floor?
Leaflessshadetree
Don't ask.
I'd just lean an extension ladder to it at as shallow an angle as possible.
Climb the ladder and pull the TV towards me onto the ladder and slide it down.
CoogarXR
pretty sure if it has a tube in it and its heavy I am pushing it down and getting a broom
Unless you have a concrete floor, I'd be worried about the floor damage, lol. If I dropped that big ol' ***** on my 150-year-old floors, it would go all the way to the basement!
pmiranda
Austin, TX
I would absolute drop that biatch onto a mattress. Put a piece of plywood or OSB on the wall to protect it from the tumbling TV and probably on either side of the mattress since it'll probably bounce and roll.
I had to move a 40" tube TV down the stairs. They were carpeted so I just laid a piece of cardboard at the bottom to protect the floor and slide the TV down on it's (heavy) glass front. Easy-peasy.
wssix99
Chicago, IL
Build scaffolding in the room with an extra section that goes higher than the TV.
Slide the TV onto the scaffolding, then you can use a block and tackle or chain hoist attached to the top section to lift it up, then remove the decking it is sitting on, and then lower the TV down through the middle of the scaffolding section. Then take the scaffolding apart around the TV once lowered.
Samh
Canton GA
Just get some 16 foot 2x4s and make a ramp from the shelf to the floor and slowly lower it and screw some boards across it at spaced intervals and lower it in steps
pmiranda
Austin, TX
From 12 feet up that's practically straight down. A ramp would be more like 24 feet... and don't forget to anchor the bottom somehow. I still want to see the video of this, assuming nobody gets hurt.
rob1200
California
Stuntmen jumping off buildings land safely on stacked empty cardboard boxes. A stuntman weighs about the same as this TV.
So just stack up empty cardboard boxes to the level of the TV, and push/pull it off the shelf.
Cobra5150
GA
Lots of smaller boxes not 2 or 3 large ones. Also DON"T FORGET THE VIDEO in case no one has mentioned it.
GMCGarage
JRC3
Southwestern OH
Option 1: A towable backhow, flip the bucket and load the TV on.
Option 2: Install PVC airlines behind the TV.
Option 3: Blast the TV onto the bucket with PVC airlines.
1967ChevyRagtop
over there
I had L-4-5 surgery years ago. First day back from surgery.
My TV with no remote was wall mounted. Got tired of trying to walk over to change channels.
So I go get it off the shelf and waddle over to a table by the couch, realize I can't bend to put it on the table. I decided to drop it on the couch.
It bounced off the cushions, hit me in my shins, and knocked be backward over the table.
bg
shoot summ
Home Depot $50/4 hours.
I just looked a local rental place and you can do it for $32.
HD is $48, locals are almost always cheaper, just depends when you need it, HD hours and proximity might justify the cost difference.
Local Bloss has a 650lb, 18' lift for $50 for 4 hours.
Regardless, my point was this would be a great way to do it, regardless of where you source the rental.
MileHighRover
Hope the OP wasn't under it when it came down. Maybe that's why he hasn't posted back...
JRC3
Southwestern OH
Oh I wasn't arguing, it was a good idea, I was just giving pricing options. I'm a tightwad, but I do HD sometimes because they are the closest to me. And usually I print off the prices from the locals and HD will match it.
Docbentley
Chandler, Texas
Haven't read all posts on this, but given the age of that monster, a sawsall would be in order after blasting the screen with birdshot.--reduce it to small pieces.
