How can this busbar handle that amperage???
tlmartin84
West Virginia
.7mm x 19mm aluminum...11 amps max on calculator...
Yet look at the fuses it handles.
It is very possible to have 50 amps continuously running through this...1000010442.jpg
rlitman
Long Island
It also may be an alloy and not simply aluminum.
Aluminum is alloyed to reduce cracking (increase ductility), and is plated to reduce surface resistance from oxidation, but every alloy has lower conductivity than pure aluminum.
dscheidt
Are you positive it's aluminum?
Also, a calculator for an industrial bus bar, or even residential wiring, is not relevant at all to a bus bar inside a fuse box. The NEC doesn't apply to cars, and has a very high safety factor. You can easily shove 40+ amps through a 12 gauge wire.
It’s also got a whole lot more surface area than a piece of wire. Heat dissipation is the limiting thing for current capacity. And I bet the engineers have a good idea what the expected load is. Lots of auto loads are fused for peak load, and are nowhere near continuous.
KenC
oklahoma
And the length of the 'wire' has a lot to do with the rating. Find a general purpose calculator, not code compliant but engineering, online and play with loads, wire size and circuit length. Lots of variance from 'normal' sizing when distance is reduced to a few inches.
Worsedog
Central FL
Based on the fact that there are couple of female terminals which require some spring tension to insure a good connection, I'd venture that it's a beryllium copper alloy rather than aluminum.
rust in the eye
Chicagoland
What calculator did you use?
The font on the left is very common on cheap, Chinese products. Guessing it's not something OEM
As is much of the poorly translated text on the fusebox plan shown.
Cross section may be akin to #6 but this thing doesn't inspire confidence and I agree with OP's reservations.
