How clean is your garage floor?
gmwelder86
Oakdale , ca
Curious if I’m the only crazy one here who vacuums up my garage floor after every project. Just a little cordless Makita dust buster type vac so not to crazy. Grew up in a garage where my dad reloaded so chance of walking out bare foot and stepping on an old primer was pretty high add that to sensitive feet and a three year old that loves to follow me bare foot in garage it all makes sense to me.
larry_g
oregon
I keep mine fairly clean. Sweep, vacuum, and oil-dri as necessary. My time to clean is when the floor is to dirty to lay on and crawl under a rig. That said quite a few farm rigs come through my shop and a few have been known to drop a bit of dirt or mud on the floor. Sometimes it's a scoop shovel for the first pass.
lg
no neat sig line
txvwnut
Bedford, Texas
Underneath all the grinder dust metal shavings and cutoff bits it’s spotless, well there are a few oil stains but other than those...
BTL-A4
Santa Clarita
I find that cleaning up after a project helps me get everything put away and organized for the next project. I can find stuff if it's put in its place. My wife parks in the garage and I keep it clean for that reason and also so I don't track grease and sawdust in the house.
I got a buddy who works on cars all the time and his garage is a mess. Whenever I go there he's always trying to find something that he placed somewhere. He always comments how organized I am, and tells other people that my tool boxes have labels, and that they actually have what the labels say they contain! Shocking!
MileHighRover
I'm pretty **** about keeping my shop clean, and that includes the floor. It's epoxy so that makes it easy to keep clean. I take my cordless leaf blower to it pretty often. It's a bit over 1,000 sq ft so vacuuming would take quite a while. The leaf blower works well and lets me blow the dust off the work benches and clean out under my equipment.
When I was working out of my last home's two car garage I vacuumed a lot. The house before that had a two car and I had a really nice epoxy floor. I mopped that one a few times a year.
bigjon
NSW Australia
My shed gets a leaf blower and/or broom weekly. Mop (ammonia solution) at least once a month or more if it gets dirty after a project. Garage, for the wife’s daily driver, gets the same treatment but not as often as it doesn’t get a lot of use.
Both are epoxy, flakes and poly top coat. Both look as good as they did when I applied them in ‘15.
UTCiv
I regularly clean my epoxy floors (barn and garage) between projects and that usually involves:
1. Dirt, dust, other non-petroleum based project:
Sweep everything to the front, dustpan for 99%, then leaf blower out the front and off to the side.
2. Liquids non-petroleum based:
Absorb with paper towels or ready to trash rags, spray some diluted simple green, wipe it up.
3. Liquids petroleum based:
Absorb with paper towels or ready to trash rags, spray some brake clean, wipe it up.
4. Snow melt:
If still wet, squeegee out the front door, or to a drain/spot to let it dry out (if I don't want to open the door in the middle of heating. If dry, spray a little water and do the same.
5. Upkeep:
Spray down floor with water, use diluted simple green in mop bucket, mop it, then squeegee.
I like to keep it pretty clean between large projects but usually wait to do the upkeep step until I can get everything out of the area.
Garage Flooring
Grand Junction, CO
I think my wife is getting aggravated that the room I clean the most is the part of the garage I use.
2ltime
Eastern Georgia
Unfinished, old cracked concrete floor here. No daily parking, used for car projects and to store yard equipment. I keep it clean enough to lay down under a project and not ruin my clothes, but often it is not swept enough so I have to shake off clothes afterwards.
No spills are left unattended, and leafs are blown out frequent, but actually move everything and mop or sweep only happens before and after a big project. But when I have a detail orientated project in it, like rebuilding an engine or spraying something with paint, I have my routine to dust, sweep, vacuum, mop, etc the place. That happens about once every 2-3 months.
Kenstone1
I have a lot of "stuff" on open shelfing in my garage, collected stuff I should have thrown away, a product of growing up poor...
I have a 2x4 "bench" on castors in my garage that I roll out on the driveway for dirty jobs like grinding, wood cutting, sanding, etc.
Keeps the dust off my stuff/floor.
My chop saw and welder are in my shed and also rolled outside for use.
Most stuff "on the floor in the garage" is in front of the bench and I just sweep it under the bench.
I pick that up after it gets deep, and my wife nags me about if for a while:argue:
So my garage floor is clean'ish, and living in the high desert makes working outside possible.
:bounce:
zmotorsports
Northern Utah
I keep my garage floor pretty clean but after a storm it may take me a day or two to sweep and blow the garage out.
My shop floor is kept very clean except when I am in the middle of a large machining or fabrication project but as soon as the project is complete or at a breaking point in the middle of the project the shop gets cleaned and floor swept. I'm somewhat **** or OCD about cleanliness in the shop and garage both.
BigGarage
Just south of Detroit, MI.
If by "after every project" you include when I cleaned, stripped, washed, acid etched, washed again and then primed and painted my floor then I have vacuumed it once and swept it out a few times in 7-8 years. I figure it's a f**ckin' garage not a showroom:bounce:.
Dennis
SeanH
Not as often as I would like. But, I try to mop my floor every 6 months at least. But, I do the daily driver section more often. :)
Cairo94507
Auburn, CA
My garage is completely finished and has a porcelain tile floor. I use my leaf blower on it weekly and once a month I mop it and it always looks brand new. I love my tile floor.
lolaetype
North Western Arkansas
Not surgically clean but very clean. I use the handheld gas leaf blower to blow out pine needles and dirt, About every other month I mop it if it needs it, more often if I'm doing something that leaves liquids on the floor.
BB767
Philo, IL
Porcelain Tile Garage Floor Easy To Clean
My garage is finished out. I think of it as an extension of the interior living space. It is porcelain tile and therefore very easy to keep clean. I keep it swept up and vacuum as necessary.
If I clean up every time after working out there it only takes a few minutes to keep it clean.
Thomas from the "Restored 1930's Autoshop"
https://www.garagejournal.com/forum/showthread.php?t=51567
mrobins297aaa
south east michigan
at least once a year, but only in the area's that get used, other areas get leaf blower
this is my 8 year old epoxy coat floor, starting to get a few stains but has held up well it hasn't lifted or peeled any where.
