How Clean Should a Funnel Be?
honcho
Near Sodom & Gommorah (aka Wash. DC)
Just how much cleaning do you do on a funnel before putting it to use?
Background: I have a bucket of funnels, all plastic. The most common use is engine oil changes on our family fleet. Throw in various other fluid changes and fillings they see antifreeze, transmission fluid, brake fluid, water, gasoline, diesel, fuel additives and, once in a while, pesticide/herbicide. I try to at least wipe them out before putting them back in the storage bucket.
The question is how clean is clean enough the next time a funnel is put to use? For motor oil, I'll normally just wipe out with a clean rag. Sometimes I'll use some brake cleaner to clean off oily residue.
What does the crowd suggest?
bonneyman
Desert SW
I wouldn't intermix petroleum and water based products. keep those funnels separate.
Surgical cleanliness probably isn't required, but if you store your funnels upside down you should keep debris accumulation to a minimum. JMHO
larry_g
oregon
They are banging around in the back of the trap wagon. I usually rap them against the bumper to knock the rocks out before using one ....;)
lg
no neat sig line
VocaTexas
I always spray a shot of ether through the funnel before I use it to make sure it's clean. When I'm done I flush any residual oil out with ether.
tym
Pretty much my approach. I dedicate a plastic funnel to coolant and a metal one for (clean) oil. I have a ratty older metal funnel for getting waste oil in the jug for recycling.
Skin
Boston
As good as you can get it within reason. I've found wiping them vigorously out after use tends to deposit more **** (fibers) then there was to begin with so I just give them a token wipe so they don't dribble everywhere. If you're worried about it flush them before use so any debris is carried away before the real fluid is used. The slightest trace of tap water this might introduce isn't going to do anything.
sawbuck
ct.
i buy a new one for every use ... i thought they were disposible ...you guys reuse em ?
Doug Arthurs
Ontario
Use it throw it in the back of the service truck. Whatever oil I was pouring dribbles out and prevents rust in the trucks box. Next time I need it make sure there are no big chunks in it and pour away.
mrvm
PA
Mines are marked with sharpie for different fluids. Then wiped down before storage just like my hand tools.
CoogarXR
I only have two funnels that I use regularly, a short-wide one for oil, and a long-skinny one for transmission fluid. I just wipe them out before I use them. No biggie.
johninct
Safety Kleen tank after use, then brake cleaner and compressed air. Next I keep them in a plastic container.
Bighead38
Rockland County NY
Mine all best together and are stacked so they drain into an old glass bottle. Takes a long time to fill the bottle. I just grab whichever size I need and if it’s dirty from the last use I’ll wipe it out. Some of you guys are crazy.
CJM8515
I spray mine out with carb clean before I begin and let dry for a sec. If its got stuff in it Ill try and wipe it out too.
mike93lx
Richmond, VA
I leave on last oil change's oil so the plastic doesn't rust then rinse with the hose over my wife's flowers before starting the next oil change.
Or I just wipe it with a paper towel. Can't remember for sure...
rlitman
Long Island
I have a laundry detergent bottle with the top cut off that houses my grease gun. My funnels are stacked and drain into the same container.
My funnels are so clean, I worry about the paper towel fuzz left behind.
I clean my funnels with a paper towel. Once the paper comes off clean, it's good enough. Any fuzz blows right off then.
plinker
Northern Wi
I try to keep mine in some sort of sealed container to keep them clean, currently a square bucket from Menards with a layer of pig mat does ok. Some have threaded on caps and that works good as well.
Otherwise brakekleen and blow dry works 95% of the time.
JRC3
Southwestern OH
In my old garage I put a special port through the wall so I could rinse my funnel out with a proprietary cleaning solution.
danielbuck
I wipe my funnels off with a paper towel, that's usually about it. A tiny amount of oil mixture with some other oil isn't going to do anything negative, IMO.
Bert_
NW Iowa
I store them upside down and wipe before use.
A Ziploc bag though? How big of bags can you get? I think only a couple of mine would fit in gallon bags.
tym
I thought I was OCD, but there's some serous funnel freaks on here.
Different funnels for different fluids? Stored in a zip lock bag?
There's two business opportunities right there. Funnel labels and funnel storage bags.
Don't forget bins for the bagged funnels...
csargents1546
Westminster CO
I have mine stored in a funnel buddy, keeps all the dust and **** out of them, plus they drain all the extra into a bottle on the bottom.
Sent from my SM-N950U using Tapatalk
tym
What, pray tell, is a funnel buddy?
All this talk of playing with funnels sounds a bit *****...
woody 73
The Great State Up North
I thought I had a problem till I was reading this post... Thank you Lord above I am not crazy, :rolleyes::rolleyes::eek::eek: give me strength oh wise and all knowing Lord; a fast paper wipe and good till the next time!
Help give some of these men your strength oh mighty Lord above heaven knows they need it...
RedneckWelder
The Ghetto Kingdom of Methlandia
We are mandated at work by our cleanliness guidelines to use ether funnels with caps on both ends or store them in a clean plastic bags and keep them clean
We also have to cap and plug all open lines (engine oil, hydraulic, transmission, coolant, or engine air) upon removal, filter fresh oil to ISO cleanliness standards, and do a whole bunch of other stuff.
