How do I cool and heat this space effectively?
chumpy36
New garage apartment. While they were building above the garage I had them insulate the ceiling etc. It's insulated on the back wall by dirt and about half of the side are also covered with dirt. But the structure is brick. I don't fancy cutting a hole for the exhaust of a AC unit or for a mini split. I was thinking a small portable ac unit with a hose exhaust. Could I just pipe it into the interstitial space between ceiling and floor above or is that a bad idea? If I need to go through the wal, I could go through the band they put there but A sizeable hole will likely compromise it. I could go through the brick but that seems sketchy too. Any thoughts?
chinboys
Are you trolling use here?
The last pic shows an outdoor condensor of either heat pump or mini-split.
There is nothing to exhaust but the condensate to the outside or drain pipe with a 3 inch hole through your rim joist.
The power and control lines, condensate line and line set get routed and seal off in this hole.
You will also need a 220-240 V AC power line to drive the condenser unit.
C
chumpy36
that's for the apartment upstairs. I'm trying to condition the garage space.
pcmeiners
Knocking holes through the brick would require a hammer drill capable of 2" carbide bit.
Not a big deal with a rented unit from say Home Depot, multiple holes can be done in a couple hours. 3 holes, 2 for the insulated gas lines, one for the combined electric, control line, condensation line. For wood again rent a heavy duty right angle drill from Home Depot and get a 2" Foster bit, a couple if you might hit a nail. Agree with Fitter30, you only need a small mini-split. You might think about painting the floor to cut down on moisture coming through the slab.
dscheidt
When I put a mini split in my basement, I rented a core drill and bit. Drilled a 3" hole in 16" thick brick wall in a jiffy. Took longer to clean the brick dust up than to drill the hole. Everything -- lineset, condensate, and electrical -- can fit through that hole (the size required depends on the unit you're installed.), but we ran the electrical through a different hole with conduit to comply with local code.
