b-boy
When my pole barn floor was added, the concrete guy forgot to add conduit into the garage.
My plumber ran water and conduit up through the floor and had to drill the floor and remove some of the packed stone to make room for the pipes.
Unfortunately, he did a really crappy job of refilling the area. I had some grading done, and the grader was supposed to fix the problem. I just noticed that he did not. He simply piled dirt in front of it. As a result, I still have a void under the floor that goes back to about 6 inches from the edge of the concrete.
It looks like something may have made a home there as well. Probably a rabbit.
My concerns are that my water line will freeze during the winter as a result, that my floor may crack at some point, and that the vermin may start chewing on my water line..
I'm planning to dig it out, evict the critters, and attempt to back fill it with stone.
Anyone have an good ideas for fixing this? Is there any type of expanding foam that might work?
Shheeesssshhh, the extent of the void is 6" from edge of slab!!! Find some clay and pack it in with a 10 lb. sledge.
