How do I fix this?
DakotaMan
TN
Working on my car and broke a stud. Normally I’d just jb weld a bolt and move on but in this case, it can’t be tall. I was thinking an elevator bolt maybe. However I still probably need it welded.
Any ideas? Can’t find this part in a junk yard around here. It goes to a 1993 mustang convertible.
SGKent
Citrus Heights CA
is the part something every 1993 mustang would have? If so pick and pull, you pull it etc should have one easier than trying to fix it. If not get a bolt the right length then grind the head thinner and make it round. Then replace and spot weld it on the backside.
D
DakotaMan
TN
Every 1993 convertible would have this part...probably every fox body convertible.
bwringer
Indianapolis
Bolt.
Grind the needed portion of the head off.
Weld.
Or, a dollop of JB Weld might actually hold long enough to assemble and tighten. Depending on the difficulty of access vs. scaring up some sort of welder, that might be worth a try (then again if the epoxy breaks removing it again could be a giant pain).
Or if there's any access to the back side when assembled, maybe you could sneak a wrench or a pair of locking pliers in there to keep the stud from rotating while you tighten.
Leaflessshadetree
Don't ask.
Salvage Yard for the whole bracket or find an elevator bolt that matches and weld it in.
Honestly the weld probably doesn't need to be that strong, epoxy (like JB weld) might work.
ezover
3rd rock from the sun
I have some of those or close to it, some where, not sure on the size. i'll check my hidey holes in the shop when I go out this morning. i'll send you a pm if I find them.
no luck, cleaned out most of my coffee cans with odds and ends. good luck finding something to work.
joe_padavano
Northern VA
You can buy those weld studs from sources like McMaster Carr, but you have to buy a whole boxfull. I've recently had a similar need and as noted above, I just used a regular bolt and ground the head down. I'd weld it in place, not glue it.
D
DakotaMan
TN
Thanks. No access to a welder. Would a machine shop be the best place to get someone to do this?
