Mark,
Thought I would answer your question here so others could see it.
Your PM:
I ran a crossed a post you made about you using a thicker metal for your ceiling. Can I ask you what is the span between your trusses and what did you use for your ceiling and where did you get. I have 8' span between trusses and would just like to put up the steel siding on the ceiling that Menards sells then insulate but I'm afraid it will sag without reinforcement otherwise ill need to strength the trusses some how and run 2x4s perpendicular to keep the metal from sagging, I would rather just screw up metal and insulate. I started a thread a while back which you can see on my profile which might explain a little more. Thank you Mark
Mark,
I have 8' between my trusses and no 2x4s perpendicular for support, I didn't want to loose the ceiling height in the shop.
What I used was steel siding that is made for ceiling use. The metal itself isn't any thicker in gauge, might even be thinner for weight, it just has bigger bends that make it about 3" thick. I too was worried about bowing once it was insulated. I blew in about 10" of insulation and it didn't bow a bit. It's been up 10 years and still is straight.
I bought most of my steel at Menards, but at the time they didn't have this ceiling steel and I got it from a local company that just sells and installs steel pole barn siding. Not sure if Menards has it now. Sometimes they can special order some odd pieces.
Hope this helps.
