how do i mount my vise to my new workbench?
Conor
i understand the static jaw is supposed to be flush to the edge of the bench.
what i'm not exactly sure on is where the mounting holes are supposed to be oriented. (I THINK i have them the right way in the pics)
see the birds eye pics hopefully someone can explain this to me.
thanks!
and 2 of the bench setup i just got
JasonW
Orange County, California
Never thought about there being a proper way to mount a vise so I probably shouldn't comment but I can see the logic in your alignment; the holes do not exactly line up in the grain and that would wear better in the long term. Couldn't help but notice the cool band saw. Haven't seen one like that before.
Staggering the hols a bit wont hurt, but don't just go flush with the edge and the static jaw; go a bit over the edge. Also, move the vise to the right so it can swing over the side as well and clear either edge. Use large fender washers or spreader plates on the bottom of the top.
kngkong
Wellington, New Zealand
Nice vise!
Yeah, looks good to me. I would go with the wider spaced mounting holes at the front like you have. Just even it up so the front holes are the same distance to the table edge and swivel the vice a couple degrees so its back to square again.
and Outlawmws makes a very good point "move the vise to the right so it can swing over the side as well and clear either edge"
C
Conor
Thanks for all the input! I appreciate it.
The bandsaw is a portaband with a swag off road table setup. Its awesome for fabrication. I originally learned about it from Jack Olsen's garage thread :beer:
JimVonBaden
Northern Virginia
Before you mount it, make sure that it will turn in all the directions you want. My vice has about a 180° turn radius, and I mounted it about 175°, so now it doesn't turn quite parellel with the bench! :sad:
I was reusing one of the holes from the old vice.
It will turn a bit more than the photo.
Jim :cool:
csp
Franktown, CO
The two holes with the wider spacing are like that so that you can get it closer to the edge and still have the holes further back on the bench, rather than the holes close to the edge of it.
tribbles
Las Cruces, NM
It looks cool, but why did you cut away part of the bench instead of moving the vice further out?
Jim :cool:
To keep the overhang from having to support the weight of the vise plus any force applied to it. I did the same thing with mine:
The vise is centered directly over the table leg. Carriage bolts run through the 2x4s in the table frame. (Yeah, I know the tag's still on the end of the 2x4. All you OCD types will just have to deal with it. :lol: )
Gary S
Bismarck, ND
I'd suggest using the old fashioned method of bolting it to the bench, but I suppose you could try something high tech like super glue. :lol_hitti
beelsr
NE PA, USA
Seems overkill, but makes sense.
Thanks,
Jim :cool:
overkill? we are talking about vises! :lol_hitti
overkill would mount the vise to a 12" square piece of 1" plate and mount that to the bench...
funny thing though, i was typing up the same thing you posted (make sure it swings the way you want it before you drill the holes - measure twice, drill once) and my browser locked up, i lost the typing and didn't feel like typing it all in again...
Ray-CA
San Diego CA
Since it looks like you don't have a lot of room on the bench, use one of these bolted up under the work bench and one of these with the vise bolted to it.
Ray
C
Conor
^ thats a thought too...when i got the 6ft work bench i was thinking it would be lots of room. now i'm not so sure.
Falcon67
Merkel, TX
Jim :cool:
The vice design and the relation of the base to the fixed jaw begs you to clearance around the base a bit so you can stand up a long part vertically. Since I had to clearance anyway, I slid it back a hair and to the side so the front two 3/8" lag bolts would bite deep into the 2x4 bench framing. The back mounting hole uses a 3/8" bolt.
