How do I remove buttons on IR impact?
Rustyg80
How do I remove forward and reverse buttons and reverse valve on Ingersoll composite wrench like 2112, 2115, 2135? I want to clean mine and was able to disassemble everything else, but do not want to force things and break something. Thanks
tbaggz
just pull them out.on the side of the handle toward the bottom there are slots.push in the metal tabs on both sides and pull down on the air fitting.that will slide out and the trigger comes out. the forward reverse just pop in and out iirc.
stikman56
You get a small screwdriver or pick against the inside of each button and push it to the outside of the impact as you pull it outward. The button has a small tab on it that stops it from just popping out. It's easier on the 2115,2135 than the 2112, 2131, because of the lip around the button to catch with the screwdriver.
Once you get them out the direction valve comes out through the bottom of the handle. There's two o-rings on that.
Before you do remove the buttons,pay close attention to the position of the direction valve ( look at in inside the housing, since you say you have it apart) with the reverse button pushed in, as this is the position it will need to be in when you put the forward button back on FIRST, this will make it even as it should be.
R
Rustyg80
thank you for help especially stickman56. Took it apart and cleaned everything as much as I could, looking much better now.
