How do I setup a trolly for a hoist?
S
Spta97
Did you do a Google search for "unistrut trolleys"? You just need the longer ones, right?
I have the trolley from McMaster Carr. I believe it is the same dimensions as the unistrut trolley. Although a longer one would work, angle iron would be cheaper. I've spent about $300 over budget as it is
S
Spta97
Spta: it's just rectangular steel tubing. I'm at the airport, so can't measure.
You can likely buy from a local steel supplier. Mine came from my model shop at work.
thanks - I'll check to see if there are any in the area.
S
Spta97
Since the top of the hoist brackets collide with the track supports, I would drill through the uprights on the hoist brackets and thru bolt. After drilling remove hoist brackets and cut off the top . You'll now have four angle clips with holes to reattach to hoist without the top hitting.
Good idea. I'll leave that as a last resort.
lakeroadster
Central Colorado
If you do this use the same size bolts and nuts as the ones that are used to attach the hoist to the trolley.
Leave the angle clips as long as possible.. this transfers the crushing load that tries to collapse the side of the tubing up to the top and bottom of the tubing. Ideally you would use a spacer inside the tubing to prevent collapsing it.
BD1
north side
'' Good idea. I'll leave that as a last resort.''
You realize that the bolt will be THICKER material than that HF bracket right and STRONGER than the metric tapped holes securing it to the hoist ?
S
Spta97
I would like to avoid cutting the brackets on the hoist if I can.
That said, I stopped by two steel shops during lunch and neither had the rectangle iron. Both had only the square.
Is there an online resource for this stuff? I'm having difficulties finding it locally.
lakeroadster
Central Colorado
What you proposed BD1 changes the loading of the components, totally different loading scenario. My advice was merely as a heads up.
The factory bolts that go in vertical are in tensile, the horizontal bolts you are proposing are in shear.
With the factory design the entire bracket would have to fail. Look at the square inch cross section of the bracket... vs. the square inch cross section of the bolt.
A STRONGER bolt is likely less ductile.. not a good thing.
As for tubing... McMaster - Carr has some, not sure if they carry the size you are after. Home Depot has some too, as well as Lowes.
BD1
north side
As for a bolt, he could use a grade 5 or even a 8 if you are worried about it.
It's not any different than using a angle clip with a hole and a grade 8 bolt.
The bolt through the angle clip would be shear on horizontal as you state and stronger than the cheap metric HF ones that hold the winch.
I have used angle clips as I am suggesting to do with the horizontal bolt in shear holding hundreds of pounds and no fail. We use angle clips all the time in hanging pipe, heaters, and brackets .
I guess this must be above my pay grade. He's only lifting tires at maybe a 100 pounds and not tons. I would have no issues doing this for my self. If he is concern, do a test lift and see what happens.
Jo Diesel
St. Johns MI
Why not just shorten up your trolly mount bar so the inside bolts align with the bolts on your winch and make 4 angle brackets and mount the inside trolly bolts directly to your winch
Probably 2x2 angle by 1/4 x 2" long.
S
Spta97
I ordered the 3/4" X 1 1/2" thick walked from metal depot. The price was good but shipping is expensive ~$14. Still probably cheaper than driving around with my gas mileage.
Doubled up with the trolley it should fit with a 1/4" to spare which I will use washers to take up the slack.
The trick will be drilling high enough to get the trolleys the clearance, but low enough as to not hit the top of the bar. That and getting it all even with a hand held drill :)
Edit - I stopped at lowes again only to confirm they only have square tubing. HD was the same. Perhaps they don't carry it in NY.
S
Spta97
Thanks for the idea. I had just ordered the rectangle iron as you posted this so I'll check out this idea if it doesn't work out.
D45
NW INDIANA
I would like some pictures of you final setup, from a distance, so that I can picture exactly how you did this
S
Spta97
Sure thing - hopefully I'll get the metal tube for the new trolley Friday so I can take final pics this weekend.
S
Spta97
Got 'er done
Well I finally got everything finished and the tires up on the rack. Lifting with an axel strap (wrapped with a microfiber towel) was easy. The hard part was getting the tires into the rack.
On the initial test I noticed the top of the tires would actually hit the hoist when up in the rack. What I ended up doing was getting them up even with me on the ladder, then little by little walking the tire over the first chrome bar (good thing they are rubber as its grippy). Then I would lower the hoist to give me enough slack to get them in the rack. Since I couldn't get them above and lower into the rack (hoist isn't high enough) I might have accomplished the same with a static mount. Oh well. If I move this sucker is coming with :)
There was some trial and error in my technique and the tire got away from me once (good thing it was attached to the hoist!).
I put a security cable though the rims attached to joist eyelets / carabiners in the unlikely event of an earthquake or other shaking that could free them from the rack.
I let them sit up there for a day and didn't see any sagging of the rack so I took a chance and pulled my car in (gulp!).
Here they are up in the rack:
Here's a view with the hood of my car open so you can get a sense of how high up they are (the top most part of the hood is about 6' in the air).
Anyway, as long as they stay up there I'm a happy camper. I wanted give a big THANK YOU!!!!!! to everyone as I could not have done it without your help!
BD1
north side
I would have sold house and moved . :lol:
Well, persistence really paid off. Great it was a success and you reached your goal. Sometimes our projects take longer and we end up spending more money.
Ok, ALL THE TIME !!!!:beer:
jaleonard3
New Braunfels, TX
I had the same problem. Simple fix, use 3/8" grade 8 bolts to attach the unistrut carriages instead of the larger 9/19" bolts. Problem solved and still an exceptionally strong mount.
n20junkie
Grand Island, NY
I love the people overly concerned with cost.
Most of us here have built a garage bigger than most peoples houses just for all of our toys to fit into.
kbs2244
Do a you tube search on hoist trolley.
More videos than you can count on how to do it.
jaleonard3
New Braunfels, TX
I've followed the trail that others in this thread blazed. I mounted my hoist on a unistrut rail. I used three double roller trolleys instead of two. I used 3/8" grade 8 bolts to mount the trolleys. Using the smaller bolts eliminates the interference between the rail hangars and the brackets on the hoist that the trolleys are mounted to. The rail is secured to the overhead ceiling joists (2 X 10) with 6" lag bolts. To address the problem with interference of the carriages with the strut suspension brackets, use 3/8" diameter, grade 8 bolts to clamp the carriage between the inistrut clamping brackets. I completed it yesterday. I used this hoist to lift and place the beds for my new 8" jointer on the base. The beds weigh 330 lbs. It worked very well and this little hoist didn't have any issues with it. Thanks to you all who showed me how to do this on this thread. I appreciate it and I've learned a lot from all of you.
View media item 74082
