How do I take this Indestro? Ratchet apert?
S-K Tool Fanatic!
NE Ohio
I got this Westcraft ratchet that I’m fairly sure is an Indestro from my cousin. But the problem is I can’t figure out how to take it apart to clean the inside. So if anybody knows please tell us. Thanks in advance.
-Tommy F53E7C9B-D5D5-4E52-AD12-157765EAC5BB.jpeg83F37F81-9848-4B85-B872-B15C52517C4C.jpeg43FB7B67-12E5-4435-B6AE-959CCE93575A.jpeg
bonneyman
Desert SW
Get a hypodermic needle from a medical supply store and "inject" you 50/50 atf - acetone mixture thru the "oil" hole. You'll probably be surprised at all the black junk that comes out of it!
What he said! I spray a bunch of brake cleaner in the hole and wash out the old grease or whatever is in there. After the brake cleaner evaporates, I take 3 in one oil and squirt a bunch in the hole. Those ratchets are strong and almost indestructible (except for the directional lever) once cleaned and lubed.
-DonC002DE16-C251-473E-A7A0-84ECB037769F.jpeg6E1883EB-63D9-44CA-A470-72D8584F89E8.jpeg1CB900F1-1C14-4618-8C5A-547F32EBDC0A.jpeg
S-K Tool Fanatic!
NE Ohio
That helped a little bit, but still one of the worst feeling ratchets I’ve ever felt, I would give this thing away If I could
-Tommy
Let her soak a few days. Looks like someone was smacking the faceplate with something
That pressed-flange unit had (at most) a 36-tooth mechanism. They are a bit "clicky-clacky" - it's not a racehorse, but it'll get the job done.
