Jaguar Fan
A simple/dumb electrical wiring question.
In a storage room in the garage of a condo (hence I don't have much ability to modify things), I have a standard single pole switch that turns the overhead light on/off.
I'd like to replace that single pole switch with a combo switch/outlet where the switch controls the light, and the outlet I can use for a standard electrical application.
I picked one of these up at Home Depot: http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=388753§ion=10070&minisite=10026
The directions inside this combo receptical say:
TO INSTALL:
Caution: when installing these devices, a Neutral wire is required for the outlet portion. When only one Black and one White wire are present in the wall box, the the White wire is not necessarily a Neutral wire. If you are unsure or unable to determine the polarity of the two wires, consult a qualified electrician.
Whoops. When I remove the existing single pole switch, there are 3 wires: ground, White and Black. I thought White was always Neutral.
Do Not Use to replace a switch that had been controlling a light with only two wires present.
Well, that's exactly what I have, sort of: one white & one black & one green.
Am I out of luck? Is there a different way to accomplish what I want to accomplish (a light and an outlet?) Did I buy the wrong part?
The diagram inside the package shows two ways to wire this: one where the single pole switch turns off juice to the outlet, and one where the outlet always has electricity. It has to do with breaking off a "fin" that connects screws on one side of the combo unit. However, both diagrams show line & common attaching on the "left" side, and one or two loads on the right side. I don't have that wiring scenario: just one black and one white.
What do I do?
Thanks
TO INSTALL:
What do I do?
Thanks
