How do I wire this motor?
Tedison
How do I wire this motor? The ground wire seems obvious as it is green/yellow and connected to the frame. Black should go to black. But then there are multiple wires (brown, red, grey, blue). Motor came out of a GE Window unit AC and had multiple speeds for the fan. My son and I are making a radio telescope and need two inexpensive motors to aim the dish and plan to use this as one of the two. So my ask is what wire or combination of wires do I need to connect to the white wire to run the fan? Can I control the speed a little by choosing a specific wire? There would be some super bonus points for anyone who can point me to some DIY plans on how to make a mount that allows for movements in two axes pointing at the sky. I think it is called a gimbal? Haven't found anything yet. Thanks in advance for any help.View attachment 2132757
The Cobbler
not sure if there's a standard on wire colours & speeds, but that's what you have , a multi speed motor . you may have to just try each lead and see what you get
can't visualize how you plan to use it to aim , do you have a speed reduction that it's going to hook to?
micromind
Fernley, Nevada, about 30 miles east of Reno.
That's a permanent split capacitor fan motor, 3 speed.
If there are 2 browns, they connect to a capacitor.
If only one brown, it connects to one side of the capacitor, the other side goes to the incoming hot.
Black might be the incoming neutral but gray could be too, no way to know without the wiring diagram.
The other wires are for different speeds, connect only one pod them.
Further, this motor will have very low starting torque and the different speeds will work only if some sort of load is connected to the shaft.....like a fan......lol.
If the A/C unit is large, the motor might be 230 volts, same as the power it's connected to.
walta
Dutzow Missouri
To my ear this motor does not sound like a good fit for your project. This motors slowest speed option seems likely to be about 900 RPM and is not easily reversible.
I would look for an old sofa or chair with a power reclining motors. This will let you move slowly in both directions.
Walta
dogdog
Probably the wrong motor for the job even if you can get that fan motor running. That’s already mentioned. Maybe look into some servo motors if it is industrial grade or some of those cnc motors like stepper motors nema23 ? And get a proper driver for it.
Not sure how old your kid(s) are, just driving back from a long drive hearing a pod cast about local high school robotics programs with MIT resources for robotics. Maybe have your kids take a free online course?
If you must search for a plan, maybe search for
Motorized pan tilt camera mount
Motorized pan tilt telescope mount
Or that other search gets you on the fbi list. Maybe.. lol
diy motorized auto turret
Plenty of YouTube videos on these
mm08822
& Lock in place?
I think what you really need is a servo motor, not a fan motor from a window AC.
Agreed, without a low motion speed output (as in using a gearbox) it will constantly overshoot even at 900rpm.
A servo will give speed control and position control. With feedback on, it will stay locked in at commanded position or current position depending on control scheme used.
T
Tedison
Having trouble with picture uploads on this forum. Maybe I can retake pictures at lower resolution
T
Tedison
I believe treadmills and vacuum cleaners use step motors? My son is on the robotics team and is familiar with them. Trying to do this with all salvaged parts.
T
Tedison
Picture of the motor tag would be very helpful
Please let me know if you can see the pictures I posted in FB. For some reason I cannot upload pictures to this thread
T
Tedison
Here you go.
I still don't see how you're going to (successfully) use this for position control.
With gears? I understand that a stepper motor or servo would be better, when I looked at them they were pricey and the goal of this project is to do it on the cheap mostly with salvaged or 3d printed parts. I don't have any experience with setting up or gearing motors so I appreciate the insights that your response and others have given me.
Viper98912
GA
For position control, I'd also recommend some type of servo or stepper motor. You can probably find some cheap hobby ones on Amazon
PCustoms
VT
I suppose you could gear in super low and run a "controller", but really it's just on/off and timing based on RPM. Kind of crude and not really how things work, so not sure the learning value.
Looking quick you can get small servo motors on Amazon for $10-$15, not sure what the controller costs.
American Locomotive
Rhode Island
The diagram shows how to wire it. The capacitor (you still have it, right?) goes between grey and brown.
One of your hot feeds gets connected to grey, then the other hot feed goes to red, blue or black to select speed. However as others mentioned, I don't think this motor is super appropriate for what you're trying to do.
