How do organize your ratchets?
lilscorpion
Colorado
That would drive me insane :scared:
you have to organize by photoelectric work funtion of the finish THEN by the primary metallic crystalline structure, if you would put some thought into it it just makes sense :D
later jim
We're talking about ratchets right? The ones we put sockets on? Off to dictionary.com. Photo-centric, parabolic, iso-metric...sheesh.
dimensionseven
I use magnetic rails to keep the ratchets and extensions in one spot. Works great. :thumbup:
where do you get magnetic rails like that? i like the idea alot. just don't even know where to find something like that. haha.
Outline
's-Hertogenbosch, The Netherlands
I have 14 different ratchets in my drawer as i speak. Their different lengths and different teeth..some flex some not. They each have a different purpose . I work on big trucks and tractors. And yes they are laid out perfect. Polished each packed with greese and a touch of oil. I even have a small piece of steel wool to polish out any scratches !!
At the moment I have 17 ratchets (4x 1/4", 3x 3/8" and 10x 1/2"). I am trying to sell 5 1/2"s and awaiting one new 1/2", a Gedore 1993 U-2 'Magic Edition' (which are the yearly promo offerings and in this case clearing out last stock). That 1993 U-2 is one (or the) last Gedore ratchet that is (completly) manufactured in Germany!
From the 10 1/2"s I have 5 in the same model. 3 of them are refurbished, 2 are brandspanking new. But that's because I used to work as a salesman in the toolbusiness. When my employer and we 'split up' (to put it in a nice way), I kept them. They weren't on any stock anyway... Rest is all different: Brand/type/number of tooth. Great to have some choice!
Mine are also freshly greased and clean. Do not polish them but keep them really clean. Small but important difference.
About greasing your ratchets: Make that the first thing you do when you buy a new ratchet and repeat it on a regular basis, depending on usage. I know first hand that getting a well greased ratchet from the factory is not always gauranteed. I have seen warranty claims with ratchets that had no grease at all in them up to too much grease!
I use a normal purpose grease, like bearing grease. At the moment JD Grease-Gard Premium, which a dealer (a former customer of me) gave to me. Why this one? It's thicker so it wont run out of the gears and makes your ratchet quiter compared to ratcehets with thinner greases and oils. Yes, your ratchet can be quiter with a thicker type of grease! The more 'metallic' your ratchet sounds, the thinerer grease they used in the factory!
Regular cleaning out the old grease and replacing it with new will cut down on the wear & tear of your ratchet because you clean out all the metal chips that come from your gears. Cleanin that gunk out and putting new grease in is THE best thing you can do to preserve the inners of your ratchet apart from not using it at all!
How much grease is enough? Simple: Put a generous amount of grease on the gears, mechanism and so on. Assemble your ratchet WITHOUT the closing plate. Make about 5 360's in one direction. Clean out the grease that oozes out the gears and so on. Repeat process in opposite direction. Finally close your ratchet. This procedure ensures that you have enough grease to keeps things lubed but not to much have it running out our ruining the inners.
I hope it was helpfull for y'all....
jjjrmx5
Cincinnati, OH
Sadly , it's a very BAD idea to magnatize your ratchets and most other tools if you work in a metal fab shop or metal grinding facility. :(
I;ve worked around armor and custom fab metal work long enough that once you set that ratchet down in the bare empty interior of a metal shaving laden vehicle it's acts like a giant magnet. A really BIG friggin' magnet. There's a reason I keep multiples sets of tweezers around. Get enuff metal shaving in you hands and you learn they hurt like a *****.
I have a hard enough time with the Snappy ratcheting screwdrivers and their magnetic bit holders which magnatizes the bit and thus the fastener. They look furry once you set them down.
Bigger tools = moar attracted shavings.
That would drive me nuts.
It's bad enough the shaving get into the roll cab dwrs. due to blow guns. A magetic rail and thus magnetic tools would be so annoying.
If you don't work anywhere near where metal is altered in any form, it may work for ya.
Not me though. LOLOLOLOL.
dmaxalliTech
A picture of my "socket drawer" from the Feb 09 issue of 8-Lug magazine, ratchets just piled in:dunno:
Farmall450
Marengo, Illinois
How much time do you guys spend cleaning and aligning your tools? Most of them dont even look like you use them, just have a little tool carshow with them! Nothing with even a scratch, a bunch of sockets without a spec of grease in them or a smudge on something LAME!
Or maybe they just take good care of their stuff ;)
crewchief888
NW indiana
ratchets and extensions are all packed (head to handle, to save space) in a 33" wide roller cab drawer in my garage boxes.
in my service truck, shorter 3/8" & 1/2" extensions, 3/8" dr ratchets, adapters and impact swivels are in a single narrow drawer in a CM top box.
1/4" dr stuff is all together in a repurposed blow molded box, long 3/4"dr ratchet head & breaker bar head are stashed in akro bins with 3/4" dr sockets
:beer:
