How do you fix a dent on a Blow Mold Case?
winlinmac
USA
I received my VIM Tool's XZN Socket set today, and one corner of the case has a small dent. It's plastic and should be able to restore the shape. Should I place a heating element next to it? Pressing on it just makes it worse. I'm a little picky, because I stack these blow mold cases on top of the other, and the dent makes this particular case wobbly now.
bmwpowere36m3
I'd try using a heat gun to soften the area, press the case down to flatten the bottom and let it cool like that.
Otherwise, fix your OCDness
jallyn
Fort Wayne, Indiana
if you could pressurize it from an inconspicuous place with low pressure, like 5 to 10 psi, it would eventually pop out.
or if you are OK with a small hole in the corner just screw a wood-screw in part way and pull the dent out with pliers.
LXCam
I think you should bring in a paintless dent remover crew and turn it over to your home owners insurance as hail damage. Lol
FigureItOut
Bentonville AR
Pics showing the extent of the dent would help garner more effective solutions.
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
CNGsaves
KS and OK
^ ^ ^ This.
. . . OR . . since OP is always critiquing any tool for COO . . . . it's likely this plastic case is China
. . . so . . . OP needs to ship if back over for whole slew of Chinese minion to fix !! :D
LXCam
^ ^ ^ This.
Problem is....the labor pool ain't old enough to know how to read or right, so who's gonna sign for the package. :dunno:
W
winlinmac
USA
It's definitely OCD, there's no doubt about that. There's no point in requesting a replacement when the bits are still functionally sound. Somewhere down the line this blow mold case is going to be accidentally pushed off the counter, so...so be it :lol_hitti
Here are the pictures :D...
Heat from the corner, blow air in the hole, and voila, fixed, right?
